Horrible rattle from sunroof area
JDiehl
Kansas
Same here. Drives me crazy. It stops when I put pressure on the glass. Would like a definitive repair solution that doesn’t replace the whole assembly costing way too much…. But might be worth it.
itsaguything
Manotick, On, Canada
The workshop manual describes how to install all body panels including the skylights.
There is no value in hypothesizing what is the issue without any investigation. I would already have the headliner out (takes 10 mins). Though the workshop manual does not define that this is necessary.
What I didn’t see shared is how this all started. Those rails or guides don’t break on their own…. did some one stand on the glass? Push the glass open or closed? used the motor to break a roof sealed in ice?
CRYA
Napa Valley
Not sure which post you’re responding to. The original 2015 post? My update to this had nothing to do with the sunroof glass. I disagree with your comment about value. The whole point of my post was to determine if others had experienced this issue and their recommendations. That has value to me. Awesome that you can drop a headliner in 10 minutes btw. That’s cool.
