Help; Radio Worn Tires Keyless Entry Doesnt Work
cingram
HELLO TO ALL,
And thank you for allowing me to enter your world. I just purchased a 05 LR3 SE somehow I bought the vehicle off line out of state(which was by pic alone). This was prob my first mistake. Anyway, when I rec'd the truck, the keyless remotes did not work, after purchasing 4 new tires and 3 months later they are almost worn out (inside tread), (the air suspension appears to be working fine) and the radio has been playing tricks on me. First the volume went out - i thought it was the radio towers but somehow worked fine the very next day...then after a month or so volume went out again this time never to return. The LCD stayed on and eventually drained the battery. Reading thru your forum, its apparent that this vehicle has very high maintenance that is very costly. I am so disappointed someone please offer words of wisdom!!!
:confused:
Welcome to the forum... I will copy this to the LR3 section so you may get more responses. Sounds like yours has been rode hard and put up wet.
