Heater fan/cooling fan 2000 land rover disco series 2 doesnt energize....
Goblin
2000land rover discovery series 2, heater fan/cooling fan(front and rear unit) will not energize via switch.so far i have done the following.......pulled both fans and tested,changed alll relays, swapped out diode( in front unit fan box)
traced out grounds, all good, swapped out heater cooling control box for a known good unit, all to no aval. control box powers up, fan control bars up from pos 1 thru max, no fan. only thing i have noticed is at the fuse box when i power up the fan switch i loose power from the hot side of the F7 fuse,what am i missing?:stupid:driveing me nuts here.
Bad fuse box (Under the Hood)... you can either replace it or run a new fused hot to the fan relay and the switch should still work.
Goblin
thanx, i have a spare
under bonnet box, will give it a shot and let ya know.which fuse feeds F7 from the underhood box?aux?
I don't remember off the top of my head which fuse feeds the Heater-A/C fans... I just know I have made a few bypass sets to temporary fix an issue in the winter to keep people warm.
