The Apline roof glass is only available from the dealer. $300 sounds like a steal. I would be all over that. The job is relatively simple as long as you are extremely careful. The only hard/frusterating part will be getting the old glass out.
- Remove roof rails - About four screws each side. Catuion, delicate screws that are put in with locktite. You may want to have a spare or to if you break one. Try not to as they are hard to get out if they break.
- Cut the sealant bead all around the edges of the glass. This is basically a perimeter bead that goes around the outside of the glass. Big rectangle.
- Cut the sealant bead that goes through the middle of the glass. This is the hard one. As crazy as it sounds, you could use a saw z all with a longish blade to cut the bead. It will make a horrible noise, and likely crack the glass further but it is the factory method of removing.
- With two people, push up on the panel with one person in the truck lifting one side. Other person holds up. First person gets out, and goes to the other side and lifts up that side. Both move in unison to lift off the panel from the back of the truck. Use gloves.
- You then have a bit of prep work to do. You have to prep the OEM panal with cleaner and then glue primer where the new bead will go. You also have to remove all the old sealant material from the truck. Scrape and clean off all old stuff.
- Deep breath
- Once all prepped, lay down the new sealant bead. I can't remember the name of the sealant, but it is top quality. I think it was from 3M and it is really expensive. Like $25 per tube. Looks like a typical sealant/caulk tube. You have some time to then place the panel.
- Two people carefully lift over the back of the truck and move it up into position. Carefully drop one side at a time. Line up the panel, and drop one side. Quickly position and lay down other side. Push down and let settle. Ensure no problems.
- Replace roof rails
- Let settle for 4 hours until the sealant sets up
- Don't wash for 24 hours at least
- Try to vent the truck as it will smell as the sealant off gases. (Don't plan on being in the truck for extended closed in periods as the off gassing is very powerful.)
- Note, you will need good open space around the truck, including a number of feet above it. I wouldn't do it outside, nor when you need the truck soon afterwards.
- Note, there are two types of OEM panels. One with a bracket on the back and one without. This is for the electronics. Get the right one, as if you try to use the one with the bracket and try to simply take the bracket off. . .you will likely break the glass trying.
