a couple of pdf's
Towards the middle to bottom of the link below, there is a 6 page and 10 page pdf related to the fuel system.
Before you take anything apart, I suggest you print them off.
Why do you think the problem is solved by replacing the fuel pump?
I ask as there is a fuse / relay that powers same. A bad relay and no fuel so to speak.
The relay, R8, is located in the engine compartment fuse box. Just remove it and switch with a similar one in there to test.
http://bit.ly/1hrIQm5
