Engine will not start.....HELP PLEASE
K
Kastaddiction
ok so i messed up my car.....i was redoing some wiring for the nav and accidently cut the posative and negative wire at the same time. now the car will not start. the lights radio and everything still works but the car will not start. any body know what it might be? im checking all the fuses but cant find anything.....please help if anyone knows anything
nwoods
The radio has some connectivity to the ECU (engine management computer). That is probably where your problem lies. Man, that is a major bummer! You might get more technical help from a member named "10forCash" on the www.disco3.co.uk forums.
K
Kastaddiction
i know, worst timimg too, thanks a lot. hopefully ill get this resolved after x-mas.
D
drudge335i
that s__ks. Good luck. I hope you get it ruunubg again.
BELLROVER
You should have disconnected your battery first before attempting any wiring repairs/ alterations!!! What year is your LR3, it might be equiped with a **** fuse from battery possitive to the starter!!!
