Discovery 2 - fender flares
Scanachi
Ohio
Who else has had rough and porous fender flares on their Discovery 2?
I’m curious if there is a way to repair/fix them.
For those that may have replaced them with an aftermarket option, which did you choose?
Sand and repaint with plastic paint.
Scanachi
Ohio
Great idea!
When comes to grit, do you have a suggestion?
Scanachi
Ohio
Oh yeah, is there a specific brand of plastic paint that you would recommend?
Depends on how bad they are, but it is plastic, so I am sure you don't want to use too low a grit (i.e. 40 grit unless it is real bad) either way start heavy to light so several grits. Paint - Autozone sells VHT Black Plastic High Heat paint (overkill for this job, but...).
Sid1577
