What kind of noise do you have occasionally? I am using the OEM Ferodos with zero noise (but they are a little dusty).I will occasionally have some noise, which I blame the pads. Next time I'll be going with akebonos.
Akebonos, and ceramics of any type, are prone to squeal when cold... and often take a very long time to bed in. If all you care about is extremely low dust, great, ceramics are the way to go. I have Akebonos on a couple other cars and can't wait for them to wear out so I can replace the blasted things.
It is extremely unlikely the calipers are the cause of the problem, assuming the guide pins are lubricated properly. From your previous posts it sounds like you lubed the pins so that isn't likely either.Not sure if I want to change brands next time or if I want to replace the front calipers altogether.
To add some feedback experience to this post. Despite of my pads and rotors having plenty of life left last year, I replaced them due to uneven wear and vibration when applying the brakes.
10k miles later these brembos are suffering from the same issue. It is not noticeable upon harder application of brakes. Very noticeable when slowly coming to a stop or when brakes are still cold. I absolutely hate the fact I have this issue.
