I have a '97 Discovery with 174k miles, and have noticed it will run much higher temps with the A/C switched on. I've also noticed that in just about every instance that it runs higher temps, the electric fan isn't running when I switch off the engine. Usually, the fan will run for a short amount of time after the engine is off, but doesn't seem to when I run the A/C. I haven't let it run too high in the temp range, and have made sure the engine hasn't overheated.
Is this is a common problem on the Disco's, and what is the best way to go about troubleshooting the issue? I bought the LR late last summer, and the previous owner had supposedley replaced the electric fans. Is it possible to hardwire a switch for the fans that I can simply operate from the dash? Thanks!
