2016 LR4 Suspension Issue
ftillier
Supporting Member
Supporting Member
Portland, OR, USA
I stuck with the original tiny o-ring but used the rest of the new kit, all with a touch of plumbing grease when assembling. I'm not sure my leak was from the valve block, but the front was sagging quite quickly. I had the thing on jack stands for front hub replacement and got stuck due to lack of T50 bit, so pivoted to clean/refresh the valve block. Hoping it sorts it!
Longtrail
Ann Arbor
Did you also do the middle and rear block? I did the front one first; then the rear one and then the middle one. I was chasing another problem and ended up doing all valves in my hunt for a resolution... It's still sitting pretty! Good luck.
ftillier
Supporting Member
Supporting Member
Portland, OR, USA
So far just the front, but given how slowly it went up to off-road height I suspect something else is up.
Moving slowly is probably the compressor.
Still could be the compressor.
Maybe the center valve block, though.
ftillier
Supporting Member
Supporting Member
Portland, OR, USA
Yes, I'm suspecting the center valve block, if it can't store air in the tank then the compressor would be doing all the work.
Rover Range
Texas
If the front struts were depleted of air, they will take longer to fill up. The reservoir has to be filled, then the struts.
ftillier
Supporting Member
Supporting Member
Portland, OR, USA
I had repressurized the system and gone for a test drive of my new hubs. This was raising from normal to off-road upon return, the back went up quickly (a handful of seconds), the front was measured in minutes.
