siegrisd
Hi, all,
I have a 2013 L205 5.0SC and I have no interior heat. Here's what's recently been done: new front coolant pipes, new oil cooler seal, new rear crossover pipe, vacuum coolant refill. I've pressure tested the system and I've tried both of the processes in the Range Rover service manual for manual re-filling as well as vacuum filling. The upper coolant line that goes to the heater core is nice and not when the engine is up to temp, but, the lower line is still relatively cold. I've bled the system from the upper bleed screw that's near the left rear corner of the engine (passenger side, LHD), and the bleed screw that's just aft and below the coolant reservoir. The coolant that escapes from the upper bleeder is nice and piping hot, but, the coolant that escapes from the lower bleeder near the reservoir is still rather cool. Prior to replacing all of the coolant lines, the heater worked perfectly.
I've run the test procedure for the blend doors and no codes have come up.
Is there a way to test the coolant temp sensor on the rear crossover pipe? If this is defective, would it cause the no-heat problem?
Thanks very much for your help.
