Griffin2013
The main issue I encountered after installation was low volume when using the Aux connection. The volume was so low that I considered removing the unit and returning it for a refund. Note that you don't actually connect the unit to the Aux port on the rear of the center console; instead, it's connected through the new wiring harness that plugs into the back of the infotainment screen. However, you still need to switch the input mode on the factory stereo to Aux, at least according to the instructions that came with the unit.
I later discovered that the unit can operate via Bluetooth, but you need to enable it in the settings menu as shown in post #10 of this thread. Now, my phone connects to the car's Bluetooth system ("Range Rover Sport"), and the CarPlay unit activates and plays at a normal volume.
