BigBriDogGuy
I had a clogged drain diagnosed soon after I bought mine used (10 years old/100k miles) and tried various methods, like the trimmer line. Finally I took it to a local guy that specialized in sunroofs, it's all he does. He dropped the corner of the headliner on the passenger's side where it was clogged, running slowly. The rubber tubing looked sound, but when he bent the top of the hose water came pouring out of it and onto the passenger's seat. He took an air compressor and puffed some air into the line in short blasts. Pretty quickly, you could hear the clog give way and debris pushed out of the drain hose. Once the line was cleared, he blew it out more vigorously with the air hose. After, we ran some water through it and it came pouring out immediately from behind the front wheel. The difference in the speed and volume of the flow was night and day.
Took it back to the same guy a few months ago to do some preventative maintenance. I was worried that clog might come back. I was ready to have him repeat the process he had used to clear it the first time. Instead, he took a water bottle and poured some into the sunroof gutter connected to the drain hoses. The water came flowing out immediately once again. He shrugged his shoulders and said it was still working fine.
