Any tips for SYA kit strap routing
theegovernor
denver
Hello I installed the SYA kit last year and havent had good luck with the straps in he rear. The straps mounted based on the directions rub on the wheel barrel. Some members have mounted them to the sway bar link. This causes them to rub on the air spring canisters. And the cvs still bind at food droop. Where do you mount your rear straps?
MellonRover
Northeast USA
Mine don't rub. Here's the best I could do for pics. My straps have a permanent "shape" to them now, if I recall there was a twist to add some tension and make them shape that way
