Help
carl acton
:hello
I have a LR3 from hell it could have very well been a hidden prop on the "EXORSIST" it lowers an raises at will, usually at lights or stops and now My LR3 06 will not move out of entry hieght position
should I call a mecanic or a priest for an exorsisum????
REGARDS
Carl
JackMac
I'm fairly sure that there is a scientific explanation, like a ride height sensor or compressor issue. Can't really diagnose from an online forum, best to have your dealer check it out.
Does it stay at access height even when you drive it at speed?
gtc
Sounds similar to my recent ride height sensor experience (I'd also get the "roll-over" warning icon on the dash) - I recently had it replaced which solved the issue - occured mainly when pulling up to a stop light.
morrisdl
ditto, but mine was wet & cold induced failure of height sensors.
bcaese
Had the same issue just the sensors
carl acton
yes
carl acton
yes,,do you know where this ride height sensor is located
