Greasy transmission, should I be worried?
Al Pizzica
PA
This looks like engine oil and despite the ugliness is probably not a major issue. I has a slight weep from the passenger valve cover that was annoying in our last 2013 that made a similar mess but was not a threat to the vehicle at all. Wipe some of it and smell it and see if it smells like trans or engine oil, they are very different smells.
DiscoLR4
Chicago
So I finally gave up and had an LR Indy shop take a look at it. They said it's the rear seal, and quoted $2.5k. Is that reasonable? That just sounds high. I know the transmission has to come out, but still.
Don't think I'm mechanically inclined enough to take on that job....yet. Should I try to pair this job with other jobs (while I'm in there add-ons)? Any recommendations? Transmission pan swap?
itsaguything
Manotick, On, Canada
Did you look at the workshop manual... its a big job.
Frankly, I'm the kind of guy that changes fluids whenever opportunity arrises. I know nothing of your vehicle but unless the fluid and pan were recently changed...
Rover Range
Texas
It pays 10 hrs to R+R the transmission. So, quote is about right.
Also, you have to factor in things that can go wrong. Like broken cat convertor bolts.
Unless that greasy mess is hitting the ground I would ignore it and run a high mileage oil to see if that will swell the seal enough to stop the leak.
Jimmy Brooks
Pasadena California
Definitely valve cover, I have the same thing because my valve covers are shot. It drips down the back of the engine while driving.
powershift
Nevada
I'd get a second opinion to be sure unless you know those guys well enough not to stick it to you when the issue was really a valve cover gasket as mentioned. During my research prior to purchasing I don't think I even read about a rear main seal go bad but I'm sure they are out there. Nothing like the coolant system problems. I had valve cover gasket leak oil and it would smoke at the end of the off-ramp.
