Control arm fail
david cook
Fairfax, VA
I am knew to this control arm issue: car about 50K miles (2013) and failed inspection.
Mechanic said I should replace lower front right/left control arms. I do sense a suspension issue starting to show as the car goes over speed bumps and turns. It has not done any off-orading.
Two questions for everybody thats an expert here:
1. How do I know that its lower control arm or upper has to be replaced?
2. The Lemfoeder that he quoted me is 4 times the price thats available on-line. I know they have to mark up, but 4x. Whats your recommendation? Tell him I bring the part or go to some place where I bring the part?
Lower control arms are super common on these. Uppers not so much.
If you put your car in drive, accelerate to 5 mph or so, and slam on the brakes you will feel the clunk of the control arms.
How much did he quote you for the parts/install? Remember you need an alignment afterwards too.
ftillier
Portland, OR, USA
Uppers don't take nearly the load of the lowers, which is why they last so much longer. Is labor in addition to the 4x priced parts, or is that the total cost including labor? If labor is in addition, ask if you can supply the parts. There is no reason they need to mark up the parts, especially if they're not official JLR parts. If you're mechanically inclined, the lower arms are doable in your garage, they're just heavy and awkward. Then it's just an alignment.
They’re doable in your garage, but it’s almost essential to cut the old ones off if they’re seized. Mine were and my vehicle is rust free.
I used a Milwaukee M18 Hackzall.
ftillier
Portland, OR, USA
They are also torqued to a ridiculous level, which can make getting them loose difficult if your clearance is limited (i.e. you're on jackstands)
MRLR4
Michigan
He's probably using a local supplier. Some do mark them at 600 each. Tell him to mail order from AutohauzAZ or such similar place, let you BYO, or you'll go elsewhere. Can also order in MeyleHD from anyone for about $150.
Mechanic you use is irrelevant. Easy job (for a shop) and gets realigned afterwards anyway. Loyalty isn't worth a grand on an old Rover.
Jimmy Brooks
Pasadena California
unfortunately i come here barring some bad news (for me). noticed my rear passenger side tire wearing a little bit more on the outside and thought the people who did my alignment didn't do it right, come to find out that my rear passenger upper control arm is busted, not even the liquid filled bushing. has anyone replaced these themselves? are they a pain?
ugmw177
Charlotte NC
Yes, rear uppers are certainly doable in your home garage; easier than front lowers, in fact. Still need 4 wheel alignment afterwards. Also whatever alignment shop you use make sure they [or you] set vehicle in tigh tolerance mode just prior to alignment and back to "customer mode" just afterwards.
