Gear selector compatibility
Ufgator89
United States
Hi all,
I have a faulty gear selector module in my 2016 LR4 HSE Lux, part#EH22-7E453-AC. Currently a 3 month back order from local dealer, wondering if one of the 3x priced eBay options part#EH22-7E453-AD is compatible with my truck?
Any insight is appreciated.
Chris
Stuart Barnes
Los Angeles
Not sure on that part number. But the correct one is
LR090489 this is for the module with the black top, silver dial
The Land Rover name for this part is “module -transfer shift control”
Mine failed earlier this year and it was a nightmare to get a replacement. I called 15 dealers all over North America. Crazy back order and there were none available in the main jlr spares depot in the uk.
If you can get one then grab it. I was reluctant to go with a potential knock off from china. As this module is a show stopper if it fails and I do go into the desert with the kids quite a lot.
Anyway. If and when you get a spare it’s a simple plug and play to change. I’ve some video somewhere if you get into trouble.
Good luck.
Stuart Barnes
Los Angeles
Here’s some pictures for comparison.
And a warning to everyone else. These electronic gear selectors don’t like cola being poured on them.
Also just before it died the illumination ring went out.
Ufgator89
United States
Thanks for the reply, I’ve pulled the faulty module out to confirm part number. Easy piece to replace, simple plug and four screws and it’s out. Just worried the eBay version will be knockoff. Of course, only other option is truck sits for 3 months, so worth the risk. I’ll post the results when replaced.
Pics of the old as I pulled it out.
Stuart Barnes
Los Angeles
I was faced with the same option. Get calling and you’ll track one down. Took me a few hours but I got one next day.
Ufgator89
United States
Update: eBay part arrived today, although purchased from seller that claimed to be in US, item shipped from China. Arrived in reasonable time, part appears genuine based on packaging. Installed tonight and truck is now driving like normal. Will have to drive for a bit to see if part fails, but quick spin in town showed no problems. I think I’m better off than the 3 month wait dealer stated, only time will tell.
irish330
Oahu
Hi all,
Chris
Hi Chris,
When you installed the new module did you have to have Land Rover service so a software check? I am in the same situation. Looking for a part currently, but also wondering if I get the part and install it, do I have to have the software updated by Land Rover also?
Nechaken
Hi Chris,
I did this last year. Just swapped the part and it worked fine. No weird codes in IIDtool either.
chakadog
Friends I have the same problem at the moment (stuck in Park).
I have the shifter out of the car—seems like an easy replace.
BUT
I want to verify one detail that hasn't been answered as far as I can tell upthread:
What's the difference in the two-letter suffix in the part number, and does it matter?
What I took out of my 2014 HSE lux shows
JLR EH22-7E453-AA
(... but LR090489 (per Stuart's post above) doesn't appear anywhere on the part. Some sites say that LR060016 is interchangeable with LR090489.. both are listed as good for a 2014 LR4... they all *look* right with silver dial and black top...)
For parts online listed as LR090489, showing the other number JLR EH22-7E453-, I have found parts with -AB or -AD suffixes.
Found a UK site showing the full range of -AA to -AH...
So, again do the suffixes matter in this part number, or can I ignore?
Thanks.
helge
