16FujiDisco
You said they gave you the head at their cost, I’m guessing that’s $5-600? If so, that seems marginally more expensive than all the work involved in transporting it to somewhere to weld it
Correct. The head is more than that but still it's worth it. Used heads are going for $800-$1,000 and a used head is just that...used. Was it warped and shaved down? Was it cracked and repaired? Too many variables and dealers don't care to deal with that. My dealer just won't deal with used parts or parts that are repaired by independent shops, then put back in the car. I'm not always in favor of dealers but I do understand where they are coming from on this. And the bigger problem I have is how many times they will be tearing down the front end and putting it back together.You said they gave you the head at their cost, I’m guessing that’s $5-600? If so, that seems marginally more expensive than all the work involved in transporting it to somewhere to weld it
Let's see if I can answer some of this without screwing up the answers too muchWhat is the dealers plan for the stripped tensioner bolt? Just tap it oversize, helicoil it, or something else.
I understand the dealer having you over a barrel, but it is absolutely possible to weld on these engines. I had a waterpump bolt shear off on mine and neither myself nor my indie had any luck through any means of getting that damned thing out. I had it towed to a fab shop I occasionally use and they drilled it, filled it and redrilled and tapped it. It has since been good for thousands of miles.
Does the dealer already have the head off the block? If so, I would go pick that thing up (it is yours, afterall) and take it to an automotive fab shop that welds and have them verifiably tell me if it is repairable or not.
If the head is still on the block, it basically comes down to what the dealer is charging you for a new head. I would love to know this if you are willing to share. Also, is the new head dressed from the factory, or would the dealer be swapping over the cams, valves, springs, etc.? At dealer rates, it wouldn't take too much make a flatbed tow to a fab shop worth the money. I would probably go so far as to pay my fab guy for his time to go by the dealer and eyeball it if you don't want to flatbed it.
