mflecklr3
- Joined
- May 18, 2015
- Posts
- 70
- Reaction score
- 22
If you know someone in your area that has a GAP tool, you can license a 2nd vehicle for $80 (and probably a six pack).
Hey thanks for the offer! I'll let you know if we don't get one of our ownNorcalfarmer - I'm in Marin and have a scanner you can use for the calibration.
I had a similar issue on my rr after changing struts - fixed by replacing the o-rings on air line connections to valve blocks that I had removed when replacing the air struts.
I would categorize NW's commentary as "good advice" overall, but I don't quite agree with it. The pressure in each bag is controlled by the software, not the air shocks themselves. Not only do you not have to replace in pairs, but you don't really need to do a calibration, either.....however it is definitely good practice.
Owning an LR3 without a GAP Tool is like being a Plumber and not having a pipe wrench in your toolbox.
