Land Rover LR4 H7 to H8 Battery Upgrade DIY
Big Sky Country
Eww. Concerning considering I just did this upgrade with a Walmart H8 battery. I had heard they were good batteries....
Most all automotive batteries sold in USA come from the same 2 or 3 manufacturers. Poke around Google and you'll find more details on East Penn vs Johnson Controls and whatnot. AFAICT none of the batteries are drastically better or worse than the others. I buy based on price+warranty with a preference for made in Germany or USA, and AGM over non-AGM.
mmbirtcher
H7. Not sure which line though. And didn’t have a receipt from the PO.
Kuro50
NJ
Just completed the battery replacement using the guide in this thread
As some have mentioned some H8 batteries are slightly better. For it it appears I can no longer put back on the battery cover. Will this be harmful to the car or components?
I also discovered a connecter that is not attached to anything. It found it like this before I installed the battery. I’m not getting any error codes and car is seemingly functioning normally. Anyone know where this attaches to? (pic attached)
Big Sky Country
The battery cover will fit with the H8, keep trying, and figure out what is interfering.
The unplugged connector is normal, you can ignore it.
pantalones
Central Florida
Funny, I was just out swapping my old Bosch H8 with a Walmart EverStart H8 and it looks like that cable doesn't actually connect to anything, it's just taped to the positive battery cable on my LR4:
I was able to close the battery cover on both my H8 batteries (Bosch & EverStart), just took a little extra force :)
From the picture, it looks like you can position the battery more to the front of the vehicle. That will help you with the cover.
Another thing that can help with the cover is to pull the rubber weather stripping from the area around the battery, install the cover, and then reinstall the weather stripping.
WatchStander
Southeastern Virginia
Pantalones - Thank you for the excellent step-by-step description of your battery change out (ref 10APR2019 entry). Your write up made me realize I am very much like a Land Rover - yeah, I over think things and make them harder than they need to be. :)
Your write up generated some questions:
1. Why is the IID tool "optional"?
2. What are the consequences (and associated actions required) for not using the IID tool?
3. I have an Interstate MT5-49/H8 battery in my vehicle which I understand in discontinued. I was going to replace it with the Interstate recommended MTX-94R/H7, but doubt that I will after reading the positive posts about the H8 battery. Now considering the Interstate MTX-49/H8. How does the vehicle respond to the new battery if not "told" about it with the IID (or other) scan tool?
4. On a separate, but related note, are there any special considerations I should take in to account when replacing the small 14Ah aux (ECO Start/Stop) battery? I hope to replace both at the same time. When it happens, I plan to install the Interstate MTX-AUX14.
Great topic, excellent lessons learned. Thanks to all the contributors.
Big Sky Country
My speculation is that if the computers think a larger, higher-capacity battery is installed (H8)... it may possibly have the alternator "shut off" for longer periods to save 0.00425 mpg, give or take. I hate the charging system, and to date nobody has figured out how to bypass the fuel-sipping programming.
I changed mine to H8 with IID but never did the "reset" afterwards, ooops. So far, zero issues.
PE_in_UAE
