Height Sensor Voltage Range
samnt650
I understand the height sensor voltage read out are reference points. My questions: Between Access, Normal, Off-Road and Super Extended. What should be the voltage differences between these height modes?
Ruper
Chesapeake, VA
Not sure anyone on a forum will know. Use DISCO3uk.com in the wiki there are manuals they may be in there somewhere. Sorry I am no help.
Ricardowelch
1511 Willow Greene Drive
I understand the height sensor voltage read out are reference points. My questions: Between Access, Normal, Off-Road and Super Extended. Visit Autofthings to review headlight uv protection if you concern. What should be the voltage differences between these height modes?
You can try to look these for your reference. Hopefully you can find down the answer.
https://topix.landrover.jlrext.com/...F/4a10fab3-ab49-4dc6-b1a8-00b601fe077b/en_GB?
https://topix.landrover.jlrext.com/topix/service/archive/65295/air suspension.pdf
remember5
Here's as much info as I can gather. Let me know if you need other sections.
  • specs.pdf
