DIY Interior Trim Removal 2014+ L319 LR4...
iconoclast
In, Out & Around...
Does anyone on here have instructions on interior trim removal for 2014+ interior wood trim? Is it any different from the previous years with the larger wood trim pieces? I am contemplating the Euro set or having the original wrapped in leather and possibly installing dynamat if the panels need to come off.
PaulLR3
Boston
I 'd like to know how to remove the black lacquer wood piece under the screen. Mine split in half last winter when it was -22 degrees in VT.
iconoclast
In, Out & Around...
Judging by the back it looks like it is held into place by tabs and removed by sliding out but can anyone on here confirm?
Schlepper
over there
I wrapped mine with black gloss vinyl. Door cards come off easily. You slide the trim pieces to remove them. Trim by the screen just lifts off.
The door is sealed all the way up. No openings like you find in other vehicles.
iconoclast
In, Out & Around...
Still planning to do it?
Yes. Not sure if doing a leather wrap like I did on a RRS-SC I owned back in the day or purchase the OEM Euro Trim.
I haven't seen it listed anywhere or if available for 2014+ models so don't even know if I am able to acquire it at this time.
Thank you. Did you have it wrapped while the panels were on or did you disassemble all of it to have it wrapped?
Schlepper
over there
Disassembled to wrap the trim. Front doors have 5 screws.
'1 behind door pull , 2 and 3 under chrome handle caps, 4 and 5 at the bottom of the door.'
The hardest part is removing the door lock trim assembled. You slide it back to remove it. Once it's off you can remove the trim.
