Looking for instructions or video on 2007 LR3 moonroof removal and installing.
remember5
Here are the first five sections of the "Roof Opening Panel" folder of the manual.
  • Description and Operation.pdf
  • Roof Opening Panel Alignment.pdf
  • Roof Opening Panel Glass.pdf
  • Roof Opening Panel Moduloe.pdf
  • Roof Opening Panel Motor.pdf
remember5
Here are the last two sections. Hope this helps.
  • Roof Opening Panel.pdf
  • Specifications.pdf
LONERANGER
Quebec
Thanks remebers5
But I'm talking about the rear roof glass.
remember5
Oh, sorry. Here is the right section attached:
  • Glass Roof Panel.pdf
Ian Morrison
Biffo 69
Birmingham, United Kingdom
Just purchased a 2007 LR3 and the moonroof is cracked.
The actual roof costs around £600 to £700 pounds and in the UK there’s not many places that fit them. However I’ve had my 2005 discovery 3 ,2 years now and my crack on the roof panel has not grown at all. You can get windscreen repair and push the glue into the crack to make it hold until you can get it replaced.its a big job replacing the glass as your inner roof lining has to be removed as well.
