Rear differential leak?
TCM75
North Jersey
I found a couple drops on the garage floor right under where the rear differential would be. 2015 with 32k miles, but I haven't read of any real issue others have had on this forum. Could it be anything else?
silvajt
Same thing happened to my 2014 last year. It was fixed under warranty. Not sure what caused it.
howardduff
Cleveland, Ohio
I had the same problem about a month ago. I have 35k miles on my 2015 LR4. It is still under warranty and they replaced the pinion seal took about 2 hours. Seems to be ok now. good chance it is a known problem, I didn't ask. They had to order the seal, that took about 3 days. You might contact your dealer and make sure they have one before you take it in.
iSurfvilano
North Beach, FL
It's a pinion seal on the rear diff. Known issue and covered under warranty but get it taken care of as soon as you can, you do not want too much fluid to escape or it will become a bigger problem.
