Another Suspension Fault - with pattern
cluch
I had a very similar problem which worsened over time. If I let the vehicle sit for a week it would be sitting right on the bump stops.
The problem was the pressure tank that the compressor pumps into. It had rusted on the top where you can't see it because it holds snow and road salt in the winter. This was only diagnosed after the compressor and all ride height sensors were replaced.
The tank itself only cost $300 to replace but it cost me over $1500 to get there.
pchak
I bought the dryer rebuild kit, but I'm waiting for the time to install it ..
cj60
rebuild kit works for me with the exception of the bracket top bolt (pita).
crankybuoy
Land Down Under
Hope you have solved your problem but if you haven't, this may help.
My 2007 RRS had a similar situation. The front left would settle overnight but sometimes it wouldn't. After a few days of non-use the car would settle down to the stops on all four corners, but sometimes it wouldn't. The orange suspension light would always come on after about an hour of driving.
My local indie tech hooked up his Autologic and noted the rear left shock was constantly moving up and down through a 1mm range so we figured it was leaking and replaced it. Nope still settled. The next suspects were that the cross-over valves were leaking internally so we replaced both--front and rear. Nope still settled. All these parts were sourced from Landrover OZ at exorbitant prices.
Getting a little weary of this expensive suck-it-and-see method of diagnosing the problem, I asked the tech if there was a way we could test the entire system in one go. After a few minutes thought he suggested we put an oil based fluorescent die through the system, drive the car around for a few days and see what happened.
Well, that did the trick. Minor leaks were detected in the two right side shocks, nothing in the left rear shock or cross-over valves as these had been replaced and a moderate leak in the front left shock (the corner that always dropped first).
It also showed up a leaking head gasket in the just-out-of-warranty replacement AMK compressor (replaced under a recall).
Fortunately there is an overhaul kit available for the AMK so a new compressor wasn't necessary.
The three replacement shocks, the AMK kit and replacement desiccant (decided to do that too) were all sourced out of the UK at really good prices compared to local. Just had to wait a week or so for delivery.
Now everything is perfect. No warning light, no traffic light dance, all good.
Next problem? The anti-theft alarm sounding off without any human assistance. I suspect it's the bonnet latch.
06Rover
Get this software, it will tell you what the fault is, it also has a lot of other useful features like adjusting your suspension height etc. I posted this else where, and I am in no way affiliated with this guy, but this app is the best ive found so far for the LR3.
Just give it a look, you wont regret it.
http://www.rswsolutions.com/index.php/discovery-iii-lr3
And if you need the workshop manuals send me a PM.
