Forty Deuce
- Joined
- Feb 13, 2016
- Posts
- 77
- Reaction score
- 27
So, I have about 6000mi on the 2016.5 LR4 HSE. I was crawling around and exploring this beautiful piece of British steel and came across something I've never quite seen before. I've spent only a moderate amount of time under cars but all of them have, to date anyhow, been American.
Near the rear of the LR4 mounted on top of the frame near the exhaust tail pipe is a metal weight. It is shaped sort of like an inverted "U" and has a mount that permits it to swing fore and aft several degrees. I like to think of myself as a moderately intelligent man and yet, despite that, I simply cannot sort out what this contraption is or what purpose it serves.
I cannot tell for sure, since it's mounted upon the frame, but I feels about 10-15lbs. It's mounted quite solidly and not easily removed. My theories are it may have something to do with the HDC in order to determine the downward angle of the LR4 since it has fore-and-aft travel but none laterally. I don't see any wiring to or from the weights but perhaps they run internally in the frame to safeguard any wiring present.
My alternate theory? Zip. I have none. Hence, I'll turn to you wiser and more knowing Land Rover aficionados. Fire away.
