How much weight in cargo area?
vfly172
With the air suspension how much can you safely put in the trunk space for a 2 hour trip on the highway?
GSMblue
Look at your door sticker, it will have a payload weight and your axle capacities.
GSMblue
The manual gives a general rating, but the door sticker is specific to your vehicle and takes in to account any "extras" installed at the factory that can impact your payload capacity.
What I do is:
Load up.
Drive through a weigh station and check:
Front axel weight
Rear axel weight
Gross vehicle weight
Admittedly I do this with my other truck I tow with, not the LR3, but the concept is the same!
"payload" rating is close enough which includes any passengers. I don't think the "options" can add up to much. 3rd row seats weigh about 80 lbs though (removed mine and weighed for curiosity) and rear hvac may add a few so you could assign 100ish lbs to those.
I'd also think the safety aspect has more to do with speed up to a point. Rolling 50 mph on side roads you could "safely" haul a lot more lbs than 80 mph down the interstate in the event of an unplanned interaction with animal, other vehicle or bad road conditions.
+1 on the safety aspect. many people have never even had a hard stop with cargo and know what really happens. I use the factory cargo barrier in my LR4 for this reason and I also use the tie downs.
Crunchy When Wet
I have transported many refigerators a long distance in my LR3 with no issues, and a piano once (loaded with a fork lift and the back sank quite a bit until it adjusted when on).
Just don't be racing people and take it easy I think you will be fine.
