20" RR wheels on 2014 LR4
edmlr4
I just picked up my 2014 LR4 HSE about a month ago, and I'm looking at a second set of wheels for snow tires. I found a set of 20" range rover (part #72199) for $250, will these fit?
I could look for a set of 18" and use spacers, but all I can find is 2003ish discovery wheels, will these fit on my LR4?
Chris
epiclr4
This guy posted a picture of his LR4 with Range Rover Sport (20x9.5") wheels in the Showoff thread.
attachment.php
http://www.landroverworld.org/forums/showpost.php?p=147885&postcount=392
Also posted after this stating that he has no rubbing at all.
NASdiesel
I have to run a spacer on my 20" RR wheels. the backspacing makes them connect at the top of the suspension. 1" should do.
epiclr4
This is what I was thinking would have to happen with the wheels being 9.5" wide. Not sure how the other guy has no rubbing.
TheDave
I run with 22" rims (285/35ZR22), no spacer, no rubbing.
Edit: lol, I have a completely different set of wheels and tires for off-road use! It's not just for looking pretty all the time!
edmlr4
I found some 18" 6-spoke wheels off a 2003 Discovery, would this fit on my 2014 LR4, assuming I use spacers.
epiclr4
I don't think you can go back that far. I saw something yesterday about how the lug nuts were different between the wheels. I'll have to look back at my history and see if I can find the place that said that.
Yeah, the lugs are different and so is the size of the wheel hub. They won't work on a LR3/4.
