What is this hollow tube? (Image Attached)
GeoRover
I was checking out my battery area in LR3 2005 looking for Transmission ECU but discovered a detached hollow tube running from around the fusebox not connected to anything . Do you know what that is? Look at the attached pics. Is this how it's supposed to be or is it missing some connection somewhere?
Thanks for your help in advance.
GeoRover
Ah, it was battery overflow drain. Attached!
ncburch22
Yep. Some batteries require distilled water or other fluids in order to operate.
tlt
It is the battery vent tube. It is not always used, as some batteries do not have a vent.
ncburch22
Wet-cell batteries sometimes use them. If anyone uses an Optima Yellowtop battery, is it worth all the money? My current battery is fine, but plan on changing soon.
kwlr3
Check both sides of the battery for a vent. I had a battery vent tube become clogged and it ruined the 4x4 control unit. It took three months and two grand to fix it. The battery can boil and spill acid directly onto the control unit.
GeoRover
This is really interesting! The Terrain Response is not responding or working, also Low Range won't work either. The indy dealer says it's the actuator or something. Haven't gotten it fixed yet.
BTW this is a brand new battery that I installed not long ago. The replaced one was seriously corroded on the negative terminal side. Wonder if the cause is similar to what you described?
roverman
Mine was just replaced, same exact corrosion on the negative terminal. Sounds like it wasn't an isolated problem!
GeoRover
Wow! I see a pattern here. @roverman, what did you have to replace? An actuator or ECU?
Thanks.
roverman
Nope, just the battery and negative cable. Fortunately it was found when it was, sounds like it could have gotten expensive.
