- Joined
- Feb 8, 2011
- Posts
- 3,401
- Reaction score
- 93
Hey everyone,
I did the HID upgrade today after work and it came out awesome! I did take some pictures, so I will post them tomorrow. It was really easy, except a little challenging to find a good place to tape the ballast. Let me say, the difference in lighting is INCREDIBLE! Seriously, the lights look great and are so crisp and bright. I am really impressed by the easy plug and play install of the DDM kit and the light output and look exceed my expectations.
I used the extra light caps and drilled a 1 inch hole in the middle. This works great for fitting the wires through and then the rubber ring. Just to reinforce the seal, I wrapped it in electrical tape inside and out and it's extremely moisture proof now. I found that it was easier to put the wires through the light caps and get them ready first. As for the rubber thing, washer, and plastic bottom to the light protector, I took those off by slipping the first two over the bulb carefully. The bottom plasic thing I just snapped I'm half to come off.
I will explain more of where I put the ballasts, etc.
Pictures coming soon... If anyone out there is thinking about doing upgrade, do it, it's the best!!!!
Thanks, David
Thanks, David
