Manual Service Reset MY14+
Captured on TopiX today. Thought this might be useful to future owners doing their own service / oil changes. Unfortunately, there is no such manual procedure in place for earlier model years - still need to use diagnostics.
Reference SSM71851
Models LR4 / L319
LR2 / L359
Range Rover / L405
Range Rover Sport / L494
Defender / L316
Range Rover Evoque / L538
Title Manual Service Re-set Procedure for 14my vehicles
Category Engine
Last modified 16-May-2014 00:00:00
Symptom 499000 Basic Engine
Content
Information:
Manual Service Re-set Procedure for 14my vehicles is now available in TOPIX under section 413-09 Warning Devices - Service Indicator Reset General Procedures,
Also can be found on SDD the application to reset the SIA currently resides in 'Service Functions'.
Manual Service Re-set Procedure for 14my Start VIN’s are as follows and covers Petrol and Diesel engine vehicles
Range Rover Sport L494 14MY from VIN LW300000
Range Rover L405 14MY from VIN LG124982
Discovery 4 L319 14MY from VIN LA699716
Defender L316 14MY from VIN LD446699
Evoque L538 14MY from VIN LV856580
Freelander 2 L359 14MY from VIN LF382339
Indian Pune Build 14MY
Freelander 2 L359 14MY VIN DL910986
Excerpt from the shop manual:
General Procedures
Synchronization
NOTE: Make sure the Land Rover approved diagnostic equipment is not connected to the vehicle.
- Set the ignition to the ON position.
- Open the hood.
- Open the drivers door. NOTE: A service resetting message will appear on the instrument cluster.
- Fully depress both the accelerator and brake pedals and hold for 10 seconds.
- Set the ignition to the OFF position.
- Set the ignition to the ON position and check the message has been cleared.
- If the message remains, repeat the process.
