Water pump replacement - mystery plug
Localschauss
Saskatoon
In the process of replacing the water pump on my lr4. The original pump has a plug vs the replacement which has an additional hook up. From what I read online for any of the replacement quides the reference hooking up a small elbow to that area. My radiator plumbing doesn't have anywhere that I could see this would go to. Do I just plug it? Or what do I need to make this work?
This is the new configuration. It ties into the rad hose. Only real way to get it is to order complete assembly. There is a brass version available. Did your old pump not have it??
Localschauss
Saskatoon
Thanks - my old pump just has a plug where this would connect. Any chance sebody has a diagram of how the coolant routing should be, on the older style?
I couldn't find a real good picture in the manual. It is a bleed port with check valve that ties back into the regular system. I believe it prevents air buildup in the pump.
Localschauss
Saskatoon
Thank you
No my old pump just has a plug where this connection would go and routing doesn't appear to have anywhere that this bled port could connect.
My y-conenctor had the top connect back to radiator and one leg conenct to the top of the thermostat and the other leg going to somewhere behind pump.
djkaosone
'11 LR4 HSE LUX 5.0L V8
SoCal
Funny, the gray y-pipe that bends down to the right is a dead y split. The hose is supposed to go to a black plastic n i p p l e that goes to the water pump. You can't just buy that piece, but someone recently made the brass replacement version.
In hind sight, whomever did that made a genius field repair.
Localschauss
Saskatoon
Great thank you, are yous ating reroute this hose to the front of the pump as per the attached marked up picture?
djkaosone
SoCal
Exactly... here's an old pic of what it should look like.
