Water Pump leak / TSB?
Surfrider77
I tried searching the forum, but had no luck...
I know the water pumps on the 5.0 V8s are prone to failure / leaking. I swear I remember reading that there was a TSB that LR put out on this. Am I correct in thinking that? Can someone with a TopiX account verify for me before my truck goes in on Saturday?
Started about 3 weeks back I had a coolant low warning. Didn't think much of it, as I had never seen it before and simply topped it up with the garden hose. A couple weeks later, now it has come back. I have topped it up again but have smelled coolant after running the engine a while.
slavek
Hi. I recently replaced coolant expansion tank. Get system pressure tested when cold. Water pump may have residue of dried coolant.
Surfrider77
Yea, they did a pressure test. Found the pump and the crossover pipe leaking. Both are being replaced under warranty. I should be picking up my truck tomorrow. :)
  • joey
