Water on floor - 07 Sport
arm222
The passenger side floor is soaking wet and I have checked the sunroof drain plugs and they are clear. Any other ideas?
A/C drains? Is the water antifreeze or just water?
I would check the A/C drains under the Vehicle. Even if you haven't been using the A/C the drains can back up when using the Defroster (it uses the A/C).
arm222
Ok that makes sense about the defroster using A/C. It is winter where I live so right now it is being used often. Are you able to tell me where to look for those ac lines on my style truck?
Normally they are right next to the transmission one on each side. Look for black rubber hoses with a ****** on them.
tflint2112
