Tire Question #14,751 - KO2 275/55R20 on stock 20" wheels?
bash535i
First, please excuse me for making another tire question post. I have spent a number of hours trying to look through old post so as not to add an unnecessary one.
From my reading, BFG KO2 275/55R20 will work on 20" wheels, even with a slightly greater offset than stock with 2.5" Johnson Rods.
I don't particularly want to raise the vehicle more than necessary. With the stock 20" wheels (machined with black insets, 53mm stock offset), how much rubbing would there be if not raised?
If raising is required, could one of the electronic controllers be used so that only minimal lift could be programmed in and if so, would that be significantly lower than 2.5" or is the full lift needed?
Thanks for your time.
