This Is The Mod And Photo Thread!
Moose
FIRST OF ALL, PLEASE ONLY POST A PHOTO AND LIST OF CURRENT / FUTURE MODIFICATIONS.
Posts discussing the posts with photos and threads will be deleted. This is nothing personal and shouldn't be considered as more than an attempt to limit the thread to a photo of the member's truck and a list of modifications. If you have comments or questions, either PM/Email, or start a new thread.
Thanks!
I drive a 1996 Discovery SE Series One, Alpine White in color.
Mods are currently as follows:
  • Removed all extra metal and plastic from front and rear bumpers;
  • Genuine LR Front Recovery Point (Class III receiver) and skid plate;
  • Removed all carpet and padding from interior;
  • Removed rear seats;
  • Plywood panel in rear area with hinged divider between rear floor and front seats;
  • OME MD rear springs w/ 1.5" custom spacer;
  • RTE HD front springs;
  • OME N76 rear shocks;
  • Bilstein HD front shocks;
  • Custom-fabricated rear shock mounts;
  • Magellan GPS 315;
  • Cobra handheld CB radio;
  • Goodyear MT/R 235/85;
  • Flowtech glasspack muffler, no resonator;
  • No sway bars; and
  • Removed all extraneous brackets, etc. from underbelly
What's next?
  • Create and install handmade front bumper
  • Rear cargo area overhaul for false floor, mounting points, etc.
  • Remove factory roofrails
  • CB antenna
  • New radio antenna or XM
  • Rear locker
Hmmmm....I'm sure I'll add more as time goes on :bandit:
Overall (from May):
Sergei
What the hell :)
235x85x16 Interco TrXus
4.75 gears
front and rear TW shafts
rear ARB locker
front TrueTrack LSD
blue polybushes
3" NWP springs
OME suspension
Scorpion Racing rear lowered shock mounts
Green cone filter
ARB compressor with tyre inflating kit
Internals of crankcase breather redone to allow better filtering yet better flow
Mean Green Alterator
Optima red top with on-board charger
Some of lines protected by reflective aluminium tape to protect heat absorbing (more to go)
Rovertym steering dampener relocation kit
Heavy duty tie rods
Magnecor 8mm wires and Bosch 4+ sparky plugs :)
Crappy new generic muffler (to be replaced for real)
Rear plywood carpeted floor with hi-lift slide-n-lock to secure cargo
Rear plywood carpeted pockets for maps and hanging things on - like fire extinguisher :)
Rear power outlet
Pinned headliner (fixed after been VERY saggy)
"Wood" trim
Alipine headunit, Duraband 10 MP3/CD changer
Complete repaint of outside shell and some of internal shell from failing red coat to school bus yellow coat (about 14 cans of paint + about 8 of primer + about 5 of coating)
Some stickers :)
Hood blackout by viggdesign
Side vinyl stripes handcut
Side moulding with integrated wheel arches
Saudi-like style grille (hand cut :))
NWP roof rack (low profile)
NWP front winch bumper
Lightforce lights (240)
Font and rear double recovery points made of JATE rings.
Plus repairs and stuff (o2 sensors, fuel temp sensor, bolts & nuts, gaskets, blah blah)...
No doubt i missed something :)
D
discomike
My Ride
So this is my ride, a 99 D2 with 61K on it that I purchased 2 years ago.
So far thses are the modifications I have made:
Custom front bumper with Warn 9500Hi winch
3 HID lights
Custom sliders similiar to John's at E.E.
Customer rear bumper and sliders
Dual Red Top's
K&N filter
QT diff guards
ACE
CDL
Rear Detroit locker with H.D. axles
Front T.T.
3" OME front lift
2" RTM rear spacer and adjusters to 3"
Steel brake line extensions
ABS extensions
Slotted and driiled DBA rotors with kevlar pads
8mm. Magnacor plug wires with Bosh Platium Plus 4's
GPS
CB
265/75/16 BFG MT's
Spare tire lift conversion with High Lifter carrier
There are other things I have probably forgotten I installed. Now I am at a place where my truck can do more than I can.
Mike J.
C
Cozmo
Joseph
Its a 2001 DII Alpine white
Mods
Intalled Hitch reciever, trailer wiring harness and recovery shackle
Cut front bumper
Mag light mounted under drivers seat
Snorkel
Old Man Emu springs 751s in front and 762s rear
Old Man Emu shocks N107 front and N108 rear
1in spring spacers rear
Extended rear axel breather
Relocated washer bottle
Inverted spare tire carrier
Rubber floor mats front
255/85/16 Dunlop Mud Rovers
Extended Abs lines
Extended Stainless Steel Brake lines
Rear Ladder
That should be it for now?
Lighting90
Hi Guys, well I don't do mods, as I like to keep my vehicles as original as I can. More fun that way. :proud:
Anyway, here are the pics...
Slam
I have a 97' Discovery that is willow green and I love it dearly.
Mods:
Front Diff Guard
Rear Diff Guard
2 Hella 4000 lights wired to look stock in dash
3" OME lift with 1" spacers
265/75 R16 MT BFG's
Rock Sliders
Rear SG High Lift mount and 48" red lift
Factory black out hood decal
Water proof seat covers
1000W power inverter with power strip
500W JL Monoblock for a 12" W6
400W Alpine for the rest with nice alpine deck
Many more mods to come
tmiller1
2004 Land Rover Discovery SE7
Has every option that the HSE7 has, except for the Harman Kardon stereo and obviously different wheels (I wanted the HSE7, but could not find the exact one that I wanted in the entire western US - this SE7 was the closest that I could find since it was only missing the Harman Kardon stereo).
Mods since purchase:
- Flip down all-in-one DVD player
- Window tint (including alpine windows)
- Satin Black A-frame brush bar/light bar
- NorthWest Parts Voyager Roof Rack (dipped the feet and clamps in liquid rubber, but removed it from the clamps because it made them too bulky for my doors to close easily)
Planned mods:
- 2 Hella Rallye 4000 HID Euro Beams (to go on the A-Frame Brush Bar - I have a LR aux. light switch so that the control of these lights will be on the pillars around the speedometer, as stock as possible)
- Rear light guards
- Rear access ladder (for the ladder I want a genuine LR ladder instead of a custom fabrication like my roof rack)
RoverChic
I love Ryan and Rovers
The Guy Magnet = HENRY
1998 Land Rover Disco D1 LE
· K & N Air Filter – Drop in type
· After market high flow cats with the rear resonator removed
· Various recovery gear (Two straps, Rear Receiver Shackle, 2 recovery points J.A.T.E. Rings 3 3/4" (wide).)
· 48” Hi – Lift Jack
· Running boards removed
· Previously had 2” Lift OME HD Front/Rear (removed and sold ~ back to stock)
· What’s to come?? I just want the Rover to run properly. I will be installing the Rear Ladder soon.
sydeem
84 Range Rover Classic Pickup
1984 3.5L engine replaced with 1994 3.9L EFi and electronics
Original manual transmission replaced with 1994 4 speed automatic
Grill, bonnet, brakes, Swivel Ball-Joints, etc. replaced with 1994 units
Decker panel louvered
X9 Super winch
ARB bumpers front and back
Hella Off-road lights
H4 Xenon bulb headlights
Heavy duty coil springs and Bilstein shocks
Poly bushings and K&N modifed air intake
Michlin LTX M/S P255/65 tires on custom wheels
Steel braided oil cooler lines
Modified computer chip and tuned velocity stacks to match Borla
Borla Cat back exhaust
Deep Cell Yellow Optima Spiralcell battery
Garmin StreetPilot III (Works pretty good for BLM roads)
D
Desert Dog
Hi All
Here are some from our vehicle:
Rover V8 4.8l 325 bhp specifically designed for desert racing.
List of mods? It's easier for me to tell you what's original!!!
