Tensioning pulleys
Davetiler
Hi do you need to take the engine out to change the tensioning pulley
Re the alternator
Doesn't appear to be any access
Took off the cover behind the wheel and can see the bottom accessory pulley but the other is right up inside
Any help please
Dave
Stewmeat2
Washington State
Everything is tough to access. If one need into the timing belt. Now, we're going to need some time; and beers! :help:
While mainly the alernator and sometimes the top engine mount need to be removed to get your hands down to the fan belt.
Andrew375
South Africa
I hope someone can help me here... I have a freelander TD4.... with BMW M47 motor in which the serpentine belt tensioner is seizing....I want to remove the pulley, but having a problem as to how to... Does the large 24mm bolt hold the pulley in place and must I loosen that to get the pulley off the arm to replace the bearing??
Stewmeat2
Washington State
I only have info for the Freelander TD4 engine. hopefully this would help? I unable to attach the pictures from my service manual that accompany these 2 belts. There is one for the Compressor Belt and another for the Ancillary drive Belt. Not sure how else to help you out on this... Stew
ADJUSTMENTS
Drive belt - compressor - Td4
82.10.01
Check
1. Disconnect battery earth lead.
2. Remove underbelly panel.
+ EXTERIOR FITTINGS, REPAIRS,
Panel - underbelly.
3. Turn steering on RH lock.
4. Remove 3 bolts and RH splash shield.
5. Check condition of drive belt. Renew a drive
belt that shows sfor the igns of wear and splitting.
Adjust
1. Loosen clamp and pivot bolts of compressor
drive belt tensioner.
2. Apply an anti-clockwise torque of 38 Nm (28
lbf.ft) for an existing belt and 47 Nm (35 lbf.ft)
for a new belt to tensioner plate hexagon.
3. Tighten tensioner clamp bolt to 24 Nm (18
lbf.ft).
4. Tighten tensioner pivot bolt to 24 Nm (18 lbf.ft).
5. Fit splash shield and tighten bolts to 10 Nm (7.5
lbf.ft).
6. Fit underbelly panel.
Panel - underbelly.
7. Connect battery earth lead.
Or;
REPAIRS 86-1-7
Ancillary drive belt - Td4
86.10.03
Remove
2. Remove engine acoustic cover if fitted.
+ ENGINE - Td4, REPAIRS, Cover -
engine acoustic - Up to 02.5 Model Year.
3. Remove underbelly panel.
Panel - underbelly.
4. Turn steering on RH lock.
5. Remove 3 bolts and RH splash shield.
6. Position LRT-12-163 to ancillary drive belt
tensioner, turn tensioner anti-clockwise and
release ancillary drive belt from pulleys.
7. Remove ancillary drive belt.
Refit
1. Ensure pulleys are clean and damage free.
CAUTION: Examine drive belt for signs of
wear. A drive belt with cracked ribs is
acceptable. A drive belt that has loose or
missing parts of ribs must be changed.
2. Use LRT-12-163 to hold belt tensioner off and
with assistance, fit ancillary belt. Ensure belt is
correctly located in pulley grooves.
3. Fit splash shield and tighten bolts to 10 Nm (7
lbf.ft).
4. Fit underbelly panel.
Panel - underbelly.
5. Fit engine acoustic cover if fitted.
6. Connect battery earth lead.
