Stalling help
ShadeTree93'
Hey!
Recently my 93' RRC stalls after it warms ups then will not start again till it cools down. Would this by the thermostat or the coolant temp sender? Or what.........??
Thanks
Jake
Disco Mike
Possibly the temp sensor, bad coil, bad fuel pump and or a dirty fuel filter causing to much pressure on the pump, or the distributor.
I would also clean out the oil trap on the PVC line.
ShadeTree93'
Thanks guys, PVC trap is pretty new but I'll check it, had the coil checked and it was good, just did a fuel pressure test a couple days ago and the fuel filter is new also. Is there a way to test the temp sensor?
Disco Mike
With a high end scanner or read up in a shop manual or Rave CD what the signal should be and check it with an OHM meter.
