Slow turning engine
Roughtx
I have been having an on and off problem. Sometimes my rover has a very slow turning of engine. Sounds like failing battery but I have checked both the battery and the ignition. Any ideas?
Slam
Supporting Member
Supporting Member
Could possibly be the starter? Any other ideas?
D
discomike
John,
First check all your nattery and starter connections, make sure they are clean and tight. If still a problem have someone due a load test and starter draw test, this will show the problem for sure.
Mike J.
tflint2112
