Service Required
Sheila
San Diego, CA
Being I only have my RRS for only a month and half, I am not sure
if I should take it in for servicing, as the indicator message states when I turn on the vehicle.
The message is there only very briefly, then goes off. Is this just a warning/ or does it need to be reset or should it be taken in for
servicing ? RangeRover Sport 2012 63,125 miles on it. Last service date shows 10/24/2018
Maintenance inspection completed at 62,440
Any comments?
Thank you
doc5339
Chapel Hill, North Carolina U.S.A.
If you have actually been doing your scheduled maintenance I would ignore it. The message needs to be reset with an IIDtool, iLand, or by an Independent Land Rover Mechanic or Dealership.
You can google "2012 Range Rover Sport maintenance schedule" or just look in the your owner's manual to see what should be accomplished. Do not assume anything has been serviced unless you have specific records.
