Mike Sutton
Well how stupid can you be? I was using my 2013 Range Rover sport to jump another car and did the unthinkable and swapped the cables. I did not realize this at first and the Land Rover was running when connected, after 20 second the Land Rover shut off. I then saw the cables were reversed and the jumper cable were very worm, crap!
I tested every fuse and they are all good. I also reversed R1 & R7 relays but did not help. Car still has power but will not start, I hear a cluck, clunk sound and motor does not turn over; this is not a solenoid sound. Now battery is not able to keep instrument panel lit. Maybe battery is messed up now?
I am hopping some sort of fuse or relay protected the mother board!
I did test with a test light on either side of the breakers or whatever they are between the cable clamps and battery cables and they are good too.
Any help would be appreciated as I do not want to take this to the shop?
