Restricted perfomance and more....
zeksmpower
Netherlands
Evoque 2.0 TD4 MY 2016
After front accident. I start to repair. I bought the radiators and fan-assembly. First it gave fault "water in fuel" with yellow icon, "restricted performance" with red icon (without start the car). I put all the stuff on my car and filled the a/c radiator. The fan didnt work and still red and yellow icon.
Time to check fuses and cable naybe damaged drom accident.
1 fuse of 10A from engine was damaged with new one yellow ixon water in fuel was gone.
Then the fan checking. After 1 day found the 80A fuse wasnt ok. Changed also. Now the fan dont stop working without starting engine and dont stop till I turn over the key. It make me crazy.
I went to someone with OBD computer to check. It gave fault code sensor engine temperature LR074067. I changed the sensor, but still the same. What I dont understand what this sensor measures, because it is on the engine and is dry. I thought it will be oil or water on it. I thougt the waterchannel goes there from te engine.
2 weeks busy with it. Please help me.
Disco2TrailEdit4
