Replace/upgrade your battery to earth cables
antichrist
These replace Rover part PRC5235 (D1 '89-'98 and RRC '86-'94)
Consists of:
  • Made from welding cable for better flexibility
  • #1 gauge (heavier than PRC5235) battery to chassis cable
  • Separate #4 gauge battery to body cable.
  • Professionally crimped heavy duty cable lugs (strands coated with dielectric grease beforehand)
  • Mil-spec Neg battery terminal
  • All connections sealed with adhesive lined heat shrink tubing for strain relief and to prevent corrosion.
  • Cable protected by wire loom secured with zip-ties.
I personally like this setup better as it eliminates the mid-cable attachment point that is a source of cable corrosion.
Both cables are long enough to reach regardless of battery post location, if you've replaced your battery (or plan to) with a different group.
$38 shipped Priority USPS to anywhere domestic flat rate boxes go.
Price subject to change as copper prices fluctuate.
Other cables/gauges available such as:
Other Land Rover models
Alternator to fuse box (red)
Battery to starter (red)
Starter to earth
Winch power cables (red or black)
Gauges #6 to 4/0
taikoubou
Hi. I'm Norbert. Can you do for me a set of these cables for my Range Rover Classic? I don't need cable for winch.
Year 1992, engine V8 3,9.
I live in Poland, and pay by PayPal.
antichrist
My request is now outdated. I have found something in my country.
Just as well as it would have taken a lot longer than 2 days for you to receive them.
I don't come on every day. The best way to contact me is via PM so I get an email notification.
taikoubou
antichrist
A set of cables for a Discovery is around $180US, consisting of
1 Discovery 1 Battery/Starter/Alternator Cable Set
Consisting of: Gauge Length
Batt-chassis 1 24”
Batt-body 4 12”
Start-chassis 2 36”
Batt-starter 2 48”
Atl-Fuse Box 6 48”
Batt-Fuse box 6 18”
Mil-spec Positive battery terminal
Mil-spec Negative battery terminal
Copper is heavy. With shipping added in I honestly think you'll come out ahead having them made locally.
I'm surprised by how expensive shipping to Poland is.
taikoubou
Hi. I have a bit different system. The battery positive terminal is connected to the starter motor and the starter to alternator. I do not have fuse box under the hood. I will think about what should I do and I write to you a private message in a few days.
Price is not a problem. A month ago I bought Mallory distributor of USA. Shipping wasn't so expensive.
gvillalongo
