Recalls for Land Rover [RRC]
R
RadRocker
Range Rover Classic
FUEL TANK, DRIVESHAFT TO DIFFERENTIAL CONNECTION
Fuel Tank
A defect which relates to motor vehicle safety exists in 1987 through 1990 and some 1991 model year Range Rover vehicles imported by Land Rover North America, Inc.
DESCRIPTION OF DEFECT
Land Rover has identified a defect in the fuel tank fitted to a number of 1987 through 1991 Range Rover vehicles. The Defect could lead to corrosion at the bottom of the fuel tank in the area above the stone guard. If the corrosion were to perforate the fuel tank wall, fuel would seep into the space between the tank and stone guard producing fuel odors. If the odor were unnoticed or ignored, fuel leakage could eventually result and present a fire hazard in the presence of an ignition source. Reported failures are primarily from areas where road salt is used during the winter. However, all affected vehicles will have the fuel tank inspected/ replaced.
VEHICLES INVOLVED/CUSTOMER NOTIFICATION
U.S. and Canadian 1987 through 1991 Range Rover vehicles within the VIN ranges shown below are involved in this recall action: Model Year Model VIN Range 1987 All HA265406-HA301324 1988 All JA300620-JA344935 1989 All KA336636-KA395665 1990 All LA391190-LA457333 1991 SXGD MA442792-MA462136
CUSTOMER NOTIFICATION LETTER
November 30, 1995
Dear Range Rover Owner:
This notice is sent to you in accordance with the requirements of the National Traffic and Motor Vehicle Safety Act.
Rover Group, Ltd., manufacturer of Land Rover vehicles, has determined that a defect which relates to motor vehicle safety exists in some 1987 through 1991 Range Rover vehicles within a specific build range. The defect may or may not be apparent in all vehicles, however, the part will be replaced on all affected vehicles within the specified build range.
Reported failures are primarily from areas where road salt is used during the winter. However, regardless of where you live or drive, the fuel tank will be replaced at no charge to you. This action is being taken voluntarily and the necessary work can be performed by any authorized Land Rover retail dealer.
The parts necessary to complete this action are currently available at your Dealer and the time required to perform this work is approximately 2 hours.
If you have already had the fuel tank in your Range Rover replaced, it is possible that the tank may not have to be replaced again. Your Dealer will be able to confirm the kind of fuel tank that is currently in your vehicle and whether or not it will have to be replaced. If you paid for all or part of having a fuel tank replaced, kindly provide your dealer with a copy of your receipt for having the work performed and you will be reimbursed.
Please contact your Land Rover Dealer to arrange for this work to be performed as soon as possible. Your dealer is prepared to make the modification as convenient as possible for you at a time that fits your busy schedule. If you experience any difficulty in making these arrangements, please contact one of our Owner Care Representatives at 1-800-637-6837.
If your Dealer does not repair your vehicle without charge and within 60 days, you may submit a complaint to the Administrator, National Highway Traffic Safety Administration, Washington, D.C., 20590, or call the toll-free Auto Safety Hotline at 1-800-424-9393. (Washington, D.C. area residents may call ((202) 366-0123). You may also call our Owner Care Department or write to:
4390 Parliament Place
Lanham, MD 20706
Attn: Owner Care Department
Please note, if the vehicle to which this notice applies has been leased and you are the lessor, you should send a codv of this notice to the lessee. We apologize for any inconvenience caused by this recall, but trust that you understand the need to have this condition rectified. Land Rover North America Barbara R. Wheatley Manager, Owner Care
Driveshaft to Differential Connection
A possible defect which relates to motor vehicle safety may exist in some 1995 model year Land Rover vehicles imported by Land Rover North America, Inc.
A limited number of vehicles may have incorrect nuts fitted to the bolts which attach the driveshaft to the differential pinion flange. This condition could possibly cause one or both of the driveshafts to become disconnected from the differential, which could result in loss of control of the vehicle.
A total of 155 U.S. and Canadian Range Rover Classic, Discovery and Defender 90 vehicles are involved in this recall action.
June 2,1995
Dear Land Rover Owner:
Rover Group, Ltd., manufacturer of Land Rover vehicles, has determined that a defect which relates to motor vehicle safety exists in some 1995 Land Rover vehicles within a specific build range. The defect may or may not exist in all vehicles, however, the parts will be replaced on all vehicles within the specified build range.
Improper hardware may have been used to fit one or both of the driveshafts to the differentials in a Defender 90 or the front driveshaft only in a Discovery or Range Rover Classic. The failure of the hardware could cause one or both of the driveshafts to become dislodged from the differentials, possibly resulting in loss of control of the vehicle.
In order to remedy such a defect, your Land Rover Dealer will replace all of the nuts and bolts holding the driveshafts to the differentials. This action is being taken voluntarily and all Land Rover Dealers have been supplied with repair instructions. The work will be performed at no charge to you.
The parts necessary to complete this action are currently available for your Dealer to order from Land Rover North America. The time required to perform this work is approximately 30 minutes.
Please contact your Land Rover Dealer to arrange for this recall to be effected as soon as possible. If you experience any difficulty in arranging to have this work performed, please contact our Owner Care Department at 1 -800 -637 -683 7.
If your Dealer does not repair your vehicle without charge and within 60 days, you may submit a complaint to the Administrator, National Highway Traffic Safety Administration, Washington, D.C, 20590,or call toll-free AutosafetyHotlineatl-800-424-9393. (Washington D.C area residents may call (202) 366-0123). You may also call our Owner Care Department or write to: Land Rover North America, Inc. 4390 Parliament Place Lanham, MD 20706 Attn: Owner Care Department
Please note, under Federal law, if the vehicle to which this notice applies has been leased and you are the lessor..you must send a cop,y of this notice to the lessee. We sincerely regret any inconvenience this recall may cause. Land Rover North America, Inc.
tango90
