Recalls for Land Rover [RR]
R
RadRocker
Range Rover 4.0 SE
REAR AXLE TRAILING ARMS, ABS HIGH PRESSURE HOSE, ENGINE DRIVE BELT IDLER PULLEY
Rear Axle Trailing Arms
A defect which relates to motor vehicle safety may exist in some 1995 model year Range Rover 4.0 SE vehicles imported by Land Rover North America, Inc.
DESCRIPTION OF DEFECT
Land Rover has identified a potential defect in the rear axle trailing arms fitted to a number of Range Rover 4.0 SE vehicles caused by fracturing of the aluminum eye which attaches the arm to the chassis frame. Should one of these arms fail, the driver may notice an audible "knocking" noise prior to separation of the arm from the chassis. If the noise @ ignored, there is a risk that the arm will separate resulting in vehicle instability and possible loss of control.
VEHICLES INVOLVED/CUSTOMER NOTIFICATION
U.S. and Canadian Range Rover 4.0 SE vehicles within the VIN range SA300190 SA309757 are involved in this recall action.
CUSTOMER NOTIFICATION LETTER
March 22, 1996
Dear Range Rover 4.0 SE Owner:
This notice is sent to you in accordance with the requirements of the National Traffic and Motor Vehicle Safety Act.
Rover Group, Ltd., manufacturer of Land Rover vehicles, has determined that a defect which relates to motor vehicle safety exists in certain 1995 Range Rover 4.0 SE vehicles. This recall campaign relates to potentially defective rear suspension trailing arms. The rear suspension trailing arms, which connect the rear axle to the chassis, may fail by cracking and fracture of the aluminum ends and separate from the chassis. If you hear any knocking noise emanating from the rear of the vehicle, pull over at once. If this noise is ignored and the vehicle continues to be driven, there is risk that the arm will separate resulting in vehicle instability and possible loss of control, which could cause a crash. Do not drive your Ran-ge Rover if you know, or suspect, that one of the trailin-q arms has failed or is about to fail.
If you should hear a "knocking" noise in the rear suspension, stop the vehicle immediately and call Land Rover Road Recovery at 1-800-444-3700 and one of our representatives will make the necessary arrangements to have your vehicle transported to the nearest Land Rover Dealer.
Even though, to date, we know of no rear suspension trailing arm failures in the United States or Canada, in order to ensure that your Range Rover 4.0 SE does not contain potentially defective arms, we will be replacing the suspect parts at no charge to you. This action is being taken voluntarily and the necessary work can be performed by any authorized Land Rover Dealer.
The parts necessary to complete this action are currently available at your Dealer and the time required to perform this work is approximately 1 1/2hours.
Please contact your Land Rover Dealer to arrange for this work to be performed as soon as possible. Your dealer is prepared to make the modification as convenient as possible for you at a time that fits your busy schedule. If you experience any difficulty in making these arrangements directly with your dealer, please contact one of our Owner Care Representatives at 1-800-637-6837.
ABS High Pressure Hose
A possible defect which relates to motor vehicle safety may exist in some 1995 model year Range Rover 4.0 SE vehicles imported by Land Rover North America, Inc.
Land Rover has identified a possible defect in the ABS high pressure hose fitted to a number of Range Rover 4.0 SE vehicles. Should this brake hose fail, the driver would notice the illumination of the amber ABS, the red brake, and amber traction control warning lights, followed by a reduction in braking capability. However, since there are two separate hydraulic circuits in the braking system, if the hose was to fail, the secondary braking system would remain functional, enabling the driver to stop the vehicle with increased pedal effort
U.S. and Canadian Range Rover 4.0 SE vehicles within the VIN range SA300190 SA313142 are involved in this recall action.
July 3, 1995
Rover Group, Ltd., manufacturer of Land Rover vehicles, has determined that a defect which relates to motor vehicle safety may exist in some 1995 Range Rover 4.0 SE vehicles within a specific build range. The defect may or may not exist in all vehicles, however, the part will be replaced on all vehicles within the specified build range.
This recall campaign relates to a potentially defective ABS brake hose. Should this brake hose fail, you would notice the illumination of the amber ABS, the red brake, and amber traction control warning lights, followed by a reduction in braking capability. However, since there are two separate hydraulic circuits in the braking system, if the hose fails, the brakes will continue to operate but with noticeably greater pedal effort required. Should this occur, stop the vehicle and call Land Rover Road Recovery at 1-800-444-3700 and one of our representatives will make the necessary arrangements to have your vehicle transported to the nearest Land Rover Dealer.
In order to ensure that the ABS braking system in your Range Rover 4.0 SE does not contain a potentially defective hose, we will be replacing the suspect brake hose at no charge to you. This action is being taken voluntarily and the necessary work can be performed by any authorized Land Rover Dealer.
The parts necessary to complete this action are currently available at your Dealer and the time required to perform this work is approximately 30 minutes. The people at your dealer are fully prepared to serve you.
Please contact your Land Rover Dealer to arrange for this work to be performed as soon as possible. Your dealer is prepared to make the modification as convenient as possible for you at a time that fits your busy schedule. Pick up and delivery services are available in many areas. If you experience any difficulty in making these arrangements, please contact one of our Owner Care Representatives at 1-800-637-6837.
Engine Drive Belt Idler Pulley
A defect which relates to motor vehicle safety exists in some 1995 model year Range Rover 4.0 SE vehicles imported by Land Rover North America, Inc.
Land Rover has identified a defect in the engine drive belt idler pulley fitted to a number of Range Rover 4.0 SE vehicles. Should this idler pulley fail, the driver would notice a loud mechanical noise from the engine compartment accompanied by the illumination of the red battery symbol in the instrument pack and the message "ALTERNATOR FAULT" 'in the message center. In addition, there will be no power assisted steering.
U.S. and Canadian Range Rover 4.0 SE vehicles within the VIN range SA300190 SA319682 are involved in this recall action.
October 3, 1995
Rover Group, Ltd., manufacturer of Land Rover vehicles, has determined that a defect which relates to motor vehicle safety exists in some 1995 Range Rover 4.0 SE vehicles within a specific build range. The defect may or may not exist in all vehicles, however, the part will be replaced on all vehicles within the specified build range.
This recall campaign relates to a potentially defective engine drive belt idler pulley. In order to avoid possible injury from pieces of a failed idler pulley, do not, under any circumstances, open the hood with the engine running until the required work has been completed. Should the idler pulley fail, the driver would notice a loud mechanical noise from the engine compartment accompanied by the illumination of the red battery symbol in the instrument pack and the message "ALTERNATOR FAULT" in the message center. In addition, there will be no power assisted steering. In the event of a failure, stop the vehicle and call Land Rover Road Recovery at 1-800-444-3700 and one of our representatives will make the necessary arrangements to have your vehicle transported to the nearest Land Rover Dealer.
In order to ensure that your Range Rover 4.0 SE does not contain a potentially defective idler pulley, we will be replacing the suspect pulley at no charge to you. This action is being taken voluntarily and the necessary work can be performed by any authorized Land Rover Dealer.
The parts necessary to complete this action are currently available at your Dealer and the time required to perform this work is approximately 30 minutes. The people at your dealer are fully prepared to serve you. Please contact your Land Rover Dealer to arrange for this work to be performed as soon as possible. Your dealer is prepared to make the modification as convenient as possible for you at a time that fits your busy schedule. Your dealer can perform the repair at your home or business. If you experience any difficulty in making these arrangements, please contact one of our Owner Care Representatives at 1-800-637-6837.
If your Dealer does not repair your vehicle without charge and within 60 days, you may submit a complaint to the Administrator, National Highway Traffic Safety Administration, Washington, D.C., 20590, or call the toll-free Auto Safety Hotline at 1-800-424-9393. (Washington, D.C. area residents may call ((202) 366-0123). You may also call our Owner Care Department or write to:
4390 Parliament Place
Lanham, MD 20706
Attn: Owner Care Department
roverboy3766
please read my post and tell me if that could be what is wrong with mine.
Roverboy3766
my post is under range rover
Disco2TrailEdit4
