Rebuild hitachi compressor or buy new aftermarket compressor?
Mozambique
toronto
Hi,
Getting intermittant code indicating compressor is on its way out.
$CAD 110 for rebuild kit, or $CAD 300 for generic new pump.
Has anyone experience of rebuilding them re. Ease and continuing fault codes after seals and desiccant replaced?
ftillier
Supporting Member
Supporting Member
Portland, OR, USA
I rebuilt mine, but I wasn't getting faults - I broke the bracket so it was out of the car, and I inspected it. There was fine desiccant powder in there, so I decided to rebuild it. The rebuild was easy, and it still works. Depending on the codes you're getting you might want to check to see if you got desiccant powder in your valve blocks.
Mozambique
toronto
I'm getting a C1A20-64 code and 'normal ride height only available' message. I at 100k miles, 2010 LR4, so it probably time it cramped out.
Dessicant powder in the valve blocks? Is that readily apparent? Blow out with air?
Mozambique
toronto
So had a quick look at it on the vehicle. Confirmed its still got a hitachi type compressor.
The bolt on the underside holding the lower cover in place immediately snapped. Not a good start. Other two torx screws ironically came out okay.
Did you remove the mounting bracket itself, or unscrew the compressor from the bracket?
The two lower bracket bolts are accessible. Gave them an extra good squirt of WD40 as now paranoid at snapping them too :(
The upper bolt hard to access. Would need an extra long 10mm wrench. Refitting the bolt would seem problematic :(
Checked out a few videos on this. The Arnott one conveniently glosses over removing that third upper bracket bolt :)
Your thoughts appreciated!
Cthehentz
Las Vegas
I used a long ratchet wrench to remove the upper bolt, with the lower hex removed you will be able to move the compressor. When you install the upper bolt I found that using electrical tape to hold the bolt in place and use a long screw driver to add pressure on the head of the bolt will help it stay in place until it is snug.
Mozambique
toronto
Hey, thanks.
But if you are removing the three bracket mounting bolts, no need to renove the hex bolts while the compressor is on the vehicle? You can remove them to take the compressor off the bracket after the units is off the vehicle. Or am I misunderstanding you?
Cthehentz
Las Vegas
I would remove the bottom hex, that will allow you to move the compressor away from the frame to give you a little more room.
ftillier
Supporting Member
Supporting Member
Portland, OR, USA
Yeah, it's a super tight fit for that top bolt. I snapped the bracket by trying to jack by it, so I had to remove the whole thing. I can't recall if I used a socket or the 10mm ratcheting box end wrench, I think the latter.
Mozambique
toronto
I can't see there's any way to get a socket on it. Ordered a long 10mm ratchet wrench today......fingers crossed! :)
dimitricourmousis
