DaisyChainsaw
- Joined
- Jul 26, 2016
- Posts
- 2
- Reaction score
- 0
I have a 2007 Range Rover Sport HSE. I am having an issue with the rear passenger door. Here are the specifics....
- The door won't lock - if all of the doors are locked using the remote, anyone can open the rear passenger door. This makes the alarm go off.
- When you click the remote the lock/unlock lever doesn't move at all.
- Initially, the back seat passenger was unable to open the door from the inside. I have since discover that if you pull the handle and the lock at the same time, the passenger can open the door.
- When I took the door panel off and tested opening the door from the inside I was able to do it by pulling the door cable.
I can't figure out if it is the door cable, the door actuator or the door handle.
Can anyone help this little lady out?
