Please help me with the p0012 code.
yongjincho
south korea
This is the v6 4.0 engine. Timing chain and guide replacement operation. Of course, the camshaft position sensor has also been replaced. It's usually fine, but with a high rpm, the p0012 code works intermittently. But the engine has no tremors, no noise, no power restrictions. It's so frustrating. Please help me.
Rover Range
Texas
Make sure the oil is clean and at the correct level.
remember5
Attached are a couple sections from the manual that may help you trouble shoot your issue.
  • Description and Operation.pdf
  • Camshaft Position Sensor.pdf
Vintage99
