Part numbers needed.
Lewisfivelitres
New zealand
I have a 2010 range rover sport supercharged.
I want to replace supercharger coupler but while I'm in there I want to replace coolant pipes and maybe even timing tensioners. Has anyone got the part numbers for
The 2x coolant pipes needed I beleive they are called bypass pipes? The problem pipes none the less
The kit for timing guides
Crank bolt
Water pump
I think that's all
Thanks in advance
Atlantic British should get you all the part numbers you need, you do not have to order there, but they do have reasonable prices https://www.roverparts.com/
gvillalongo
